SpotlightFormatting video screen object labels
A variety of video screen object labels can be included in the drawing; most of the information in the labels comes from the Object Info palette. If the Object Info palette parameter is blank, the label cannot be selected. Different options are available depending on the video screen object.
To select labels for display and format the text:
Select a video screen object. From the Object Info palette, click Text Options.
The Text Options dialog box opens. Select the labels to display, and choose the label text size, color, and alignment. Change the default label title, if desired.
Click to show/hide the parametersClick to show/hide the parameters.
Text option
Description
Coverage Zone
Show coverage zone text
Displays the coverage zone distances and multipliers
Near/Far Note
Enter any notes for the near/far coverage zone
Only show note(s)
Displays only coverage zone notes text
Include "Multiplier" and "Distance" zone labels
Displays multiplier and distance labels in the coverage zone text
Television Size (Television)
Show television size
Displays the size of the television screen
Screen Information (Blended screen, video screen)
Show screen dimensions
Displays the screen dimensions. The dimension text order can be changed from the default height x width to width x height instead, by selecting Swap dimension order.
Include pixel counts (Blended screen)
Displays the pixel count of the screen image
Show (screen) aspect ratio
Displays the screen aspect ratio
Show (screen) trim
Displays the screen trim
Show (screen) clearance
Displays the screen clearance
Show (screen) weight
Displays the screen weight
Show Area Overlap (Blended screen)
When areas overlap, show the area as a measurement, pixel count, or percentage
Screen Unit
Displays the screen object unit information
Purpose and Note
Displays the Purpose and Note text
Projector and Lens Information (Video screen)
Select the labels to display: projector information, projector weight, lens throw ratio, and/or lens model
Projection Distance (Video screen)
Show straight distance (2D)
Displays the straight (plan) distance in 2D from the projector to the screen
Show direct distance (2D)
Displays the direct distance (projector throw distance) in 2D from the projector to the screen
Show actual distance (3D)
Displays the actual distance in 3D from the projector to the screen
Include dimension line(s)
Includes dimension lines for each of the selected distances; specify the Arrow Size and the Extension Line Offset
Projector Unit(s) (Video screen)
Projector 1/Projector 2
Displays the Projector 1/Projector 2 unit information
Multiple Projector Tag (Video screen)
For stacked projectors, indicates that there are multiple projectors
3D Area IDs
Show 3D area ID text
In 3D views, adds a numerical ID for each area of the blended screen (each area served by a projector)
3D Text Block
Displays labels in 3D views (parameters vary by screen type): dimensions, projector information, lens information, projector distance, resolution, trim, purpose, and note
Overall
Keep text horizontal
Maintains the text in a horizontal position even when the screen object is rotated; deselect this option to rotate the label along with the object
Fill text background
Allows a text background fill to be used for all video screen text; by default, white is used as the fill color. To specify a different fill color, click Classes in the Object Info palette, and then select a fill color for the class of the screen text. The class should be set to Use at Creation.
Specify the text labels and formatting.
Once the labels have been added to the drawing, they can be moved by clicking and dragging the label control point. Click Default Text Positions from the Object Info palette of a selected video object to restore the labels to their original locations.
Inserting video screen objects
